Fired it up today... 416 Stroker
Old Feb 14, 2009 | 09:24 PM
Tony B4's Avatar
Thumbs up
Mean!
Old Feb 14, 2009 | 09:36 PM
allngn_c5's Avatar
When will she hit the dyno ?? I see your old 408 did 540/480, how much more are you expecting from your 416 ??
Old Feb 14, 2009 | 11:44 PM
2001 Pewter WS6's Avatar
Restricted User
I am going to drive it for a few hundred miles before I put her on the rollers. Weather in Pittsburgh has been crappy. I will start driving it when spring arrives. The old 408 consumed a lot of oil. I made a post about it. Pistons were in backwards and 4 out of 5 main caps were on backwards as well. If it made the same power as the old 408 made, I would be happy for the simple fact that it doesn't burn oil any more. How much power was I losing from an oil contaminated charge??? I don't know. It has to be something though. I drove 20 miles to the track, made 3 passes and drove home and used 1/2 quart of oil. If I make 550/500 I will be very pleased... One thing that will hurt me is that I got rid of the true duals and went back to a catback. I am planning on putting dual DMH low profile cutouts in the Y-pipe in the future...
Old Feb 15, 2009 | 10:38 AM
allngn_c5's Avatar
Best of luck bro !! I am sure that the new motor will scream.
On the issues of your old motor, being that is was assembled with a few errors, were you able to recoup anything from the shop that built it ?? You can pm me the info if you like. No sense rehashing it on the thread if you already posted it before.
Old Feb 15, 2009 | 01:34 PM
JoeyGC5's Avatar
I was curious if you were going to have to sacrifice timing to run 12.1 : 1 compression on 93 octane. Glad to hear you didn't.
I'm running 28.5 wot and stockish in the cruise cells with my 11.8:1 LME 416 on pump 91/92. Just take time tuning it and it'll work out fine.
2001 Pewtewr WS6 sounds good
Old Feb 15, 2009 | 01:48 PM
allngn_c5's Avatar
That's good to hear. I remember reading a few of the big names say that its better run max timing before KR rather then run more compression and have to retard the ignition timing to prevent KR.
Sounds like you know what you are doing. Did you tune the motor yourself ??
Old Feb 15, 2009 | 06:25 PM
ss2000's Avatar
sounds great. looking forward to seeing it at prp.
