LS2 Timing Chain fitment problem on LSX Block
Old Mar 6, 2009 | 12:45 PM
ArmZ28's Avatar
Default LS2 Timing Chain fitment problem on LSX Block
Hello there guys,
We are now building an LSX Block with a Lunati Stroker kit and Diamond custom pistons to be fed with a 94mm EZ-94X turbocharger.
We are now facing with a difficulty, I would like to ask you about.
I just purchased a JP performance LS2 timing chain set for my block but my builder says that when he installs it to the block, it hits the 6 screws of the camshaft. Is this normal?? What do you guys think we should do about this problem? I tried to search but found nothing.
Thanks for the help.
Old Mar 6, 2009 | 04:29 PM
OneQuickCoupe's Avatar
Do you know if a stock LS-2 gear and chain set will work?
If it's just touching the bolt heads you could face a small amount off of them.
LSXNOVA
Old Mar 6, 2009 | 06:37 PM
Tom@SpeedInc's Avatar
Need to run countersunk bolts for the retainer plate
Old Mar 6, 2009 | 06:41 PM
ArmZ28's Avatar
Thanks for the help guys
