Lsx 427
Old Mar 13, 2009 | 11:16 AM
Chris'stransam's Avatar
Default Lsx 427
I am gona build a lsx 427 with ported ls7 heads and a mild cam. The cr will be around 11-1 or so . My question is how much hp will it make at the tire . The car is a 99 Transam with a m6.
Old Mar 13, 2009 | 11:17 AM
Phil99vette's Avatar
7 Second Club
Old Mar 13, 2009 | 11:29 AM
Haans249's Avatar
Yup, port the manifold and you will probably be closer to 550 depending on the dyno of your choice.
Old Mar 13, 2009 | 05:58 PM
Or should I do a 408 with l92 heads and a vortech t trim ?
Old Mar 13, 2009 | 06:03 PM
LS6427's Avatar
Here comes 5 pages.........................
Old Mar 13, 2009 | 06:16 PM
2000_SS's Avatar
uh........what do you want the car to do? there are millions of combos you could build on a given budget OR a given purpose...we need to know what YOU want the CAR to do.
i suggest you search around the site a little more, specifically in the Dyno results section. you might be able to find the info you're looking for.
Old Mar 13, 2009 | 07:20 PM
ramairws6's Avatar
Like stated ubove...........with a M6 you will be anywhere from 500-550 at the wheel.
Old Mar 14, 2009 | 02:17 AM
red02Hawk's Avatar
you realize the LS7 stuff gets really expensive, REALLY QUICK!
Old Mar 14, 2009 | 10:08 AM
7 Second Club
How about a 402/408 with a single turbo?
Old Mar 14, 2009 | 05:43 PM
JUNK's Avatar
The smaller cammed ls7 will put out around 525rwhp, the larger cammed beasts w/ higher comp. and good quench are making 560-590rwhp. These are stock engines w/ headers/cam/mild-headwork. This is using a stock LS7 intake/t-body. The #s are repeatable all day long. I saw one make 511rwhp w/ the stock 211/230 .588 cam and milled heads
Old Mar 17, 2009 | 05:49 PM
njc.corp's Avatar
Question
You got more info or a link on that?
