WOT reads 88% throttle?
Old Apr 2, 2009 | 10:35 PM
TransAm12sec's Avatar
Default WOT reads 88% throttle?
Can someone explain this in detail? As in why doesn't full throttle read 100%?
https://ls1tech.com/forums/11362456-post37.html
'I guess one should explain the GTO full throttle deal, the drive by wire set up on the 05-06 GTO reads 88% at WOT"
Old Apr 3, 2009 | 10:29 PM
DrkPhx's Avatar
You can select a different PID in EFILive that reads actual TPS for the LS2. I use it for my TB SS.
Old Apr 3, 2009 | 11:48 PM
JonCR96Z's Avatar
Yeah, you have to log ETC% instead of TPS%
Old Apr 4, 2009 | 12:55 AM
1fastxz's Avatar
the 88 you are rading is what the PCM is reading from the TPS sensor.
because of the angle the motor sits in a GTO that is how much the PCM opens the blade motor
that is 100% open in a GTO
Old Apr 4, 2009 | 02:28 PM
Braciole's Avatar
88% is 100% TPS Thats how it reads in HPTuners
Old Apr 4, 2009 | 04:31 PM
1fastxz's Avatar
thats what i said
