KOOks stepped headers install TIPS PLEASE
Old Apr 10, 2009 | 07:51 AM
dnkynrbk's Avatar
Default KOOks stepped headers install TIPS PLEASE
Well got the pass side on drop the started and cut tabs off my t400 tranny. Drivers side will not even begin to even get it. Any tips. LOOK like I need to pull the whole dam motor out to get them in frustrating.
pic or tips please
Old Apr 10, 2009 | 08:59 AM
Black Sunshine/ 00SS's Avatar
did you pull the oil filter? That has helped me in the past, surprising how much difference it makes.
Old Apr 10, 2009 | 10:27 AM
dnkynrbk's Avatar
yea pulled the oil filter. cut that extra piece off the block and cut some of the k meber off and still no luck
Old Apr 11, 2009 | 12:24 PM
mebuildit's Avatar
Patients GrassHopper, is the key to headers.
Old Apr 11, 2009 | 03:11 PM
HMERacing's Avatar
would it help to shift the trans from side to side like when installing SLP headers?
Old Apr 11, 2009 | 07:41 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I wonder if the stepped headers are different enough in design to give problems? I just got done installing my Kooks 1-7/8" headers today (they replaced Kooks 1-3/4" headers), and I didn't have to cut anything, grind anything, or even remove the oil filter or the thing right above it. They installed exactly like the 1-3/4" versions...
For the driver's side, you have to basically turn the header 90 degrees so that the collector is facing downward. That will let you go straight up with the header, and while you are going up, you can then rotate it...mine cleared the steering linkage, oil filter, etc. doing it this way. It wouldn't have gone in any other way though...
Old Apr 11, 2009 | 08:53 PM
02SOMWS6's Avatar
there must be a day and night differance between t56 and auto cause mine go in from the bottom with ease
Old Apr 12, 2009 | 08:03 AM
ramairws6's Avatar
Yepper, you'll have to pull the motormount bolts and raise the engine.....
Old Apr 18, 2009 | 11:15 PM
Jimmy P's Avatar
I have the 1 7/8"-2" and they went in from the bottom with ease. TH400 trans too.
Old Apr 26, 2009 | 09:55 PM
blk00ss's Avatar
Do you have a aftermarket K-member? I had to jack my motor up as high as I could get it, and then pull the motor mount pedestal from the k-member. BTW this is with a stock k-member, and a t56, and this is the 1 7/8" stepped to 2". It was a bitch.
Old May 20, 2009 | 06:43 PM
02PewterSS-LM1's Avatar
im with him on this one they have to be completely straight up in the air and then they will go in.. did mine in the driveway
Old May 22, 2009 | 08:43 PM
00454sscamaro's Avatar
the 1 7/8- 2 are only meant for aftermarket k members, i had to cutt alot of metal of my stock k + raise the engine about 6".
what size headers are these? is your car high enough off the ground? i did mine originally on a lift and it was a pain, i dont even wanna think about this install with car stands or similar.
Old May 27, 2009 | 03:16 PM
LS1BLKSS's Avatar
Banned Village Idiot
the kooks were a bitch to install in my car also... i just gave it time and it just slip right in..driver side... the pass. side was really easy
