I have a few header questions!!!
Old May 14, 2009 | 04:43 PM
2001taws6's Avatar
Question I have a few header questions!!!
2001 pontiac trans am,
1. I should get "race" style headers right?
2. does AIR need removed before or after headers are done?
3. what all needs to be done so that I dont throw any codes?
I deff. want cermamic coated headers so they dont rust and deff. want ORY so I dont have any CATS. I was goin to wait till winter to do this but I am forced to do it now because my passenger side catalatic converter is goin bad, so I need to get them changed out soon!
Old May 14, 2009 | 08:39 PM
Tom@ARH's Avatar
Closed ex-Sponsor Account
That depends on what your looking to do if you need to pass a visual inspection you will need to keep the air system( it does'nt cost any HP to keep it)
If you buy a race system you can remove the air anytume you want. Don't buy a non-race system then decide to remove the air because the block off plates tend to crack the headers over time.
You will need a tune to clear any codes and also get the most performance out of the system
On a stainless steel header you don't have to coat them unless you want to a quality (304 or better) stainless header won't rust like mild steel does. You can get it done but it's not a necessity. Again cats are a inspection thing and unless your doing a big head and cam setup or FI the cats we use won't hurt you more than maybe 5hp but a catless system is less expensive if thats a concern
I hope this helps you with your descion if I can help you in any way let me know
Old May 14, 2009 | 08:53 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
ARH headers are the way to go in my opinon
