L92 heads, Which Casting # is better?
Old May 20, 2009 | 08:57 AM
STEEPSS's Avatar
Default L92 heads, Which Casting # is better?
i have been looking at some L92 heads for sale, and i was wondering which casting # is better? The 823 casting, or the The 0821 casting? I have an opportunity to get my hands on some for a very reasonable price.
Also, not that i would personally do it, but would it be acceptable to run two different casting heads? Say, one 823 and one 0821?
Thanks!
Old May 20, 2009 | 09:07 AM
69LT1Bird's Avatar
search is your friend, there are 21 threads on the subject
Old May 20, 2009 | 09:14 AM
STEEPSS's Avatar
sorry i'll do that. I guess i didn't realize the search was working.
Old May 20, 2009 | 11:20 PM
Richard@WCCH's Avatar
Major geometry is identical between the two castings. There's only some minor differences in the port cores. Net flows are within a margin of error. We typically see each of the as cast heads go 325-330cfm on the intake side and 200-205cfm on the exhaust side.
Good luck,
Richard
Old May 21, 2009 | 09:41 AM
69LT1Bird's Avatar
They use a "green sand" process on the original LS3 heads which made the ports smoother. I think they now use the same process on all of the heads.
Old May 21, 2009 | 07:04 PM
8ByGoat's Avatar
I don't know about today-but 2 years ago when we did my car. We had 2 sets of heads, one was a set of 823 castings, one was a set of (not sure if this is the exact #) but it was 4 digits-maybe 5364 (something like that).
The finish in the ports of the 823's was superior in addition the exhaust ports themselves in the 823's were considerably larger.
Old May 26, 2009 | 01:36 PM
Austin@HPE's Avatar
I believe the 821 are lower cc like 68 or 70 and the others are like 72 or 70 I could be wrong.
Old May 26, 2009 | 02:28 PM
the_merv's Avatar
Veteran: Air Force
The Heads I have on my Engine are the 2 different cast numbers..that's just how I got them and I've been running them ever since. One of them is smoother than the other on the outside, but the Ports and Chambers were identical.
