Need Help, Ls6 to Ls2 TB DBW
Im Swapping a Fast LSX INtake onto an 02 Crovette and going with a ls2 TB, Anyone have any wiring Diagrams to help me out?
Id like to just repin the New connector on ls6 harness with an ls2 pigtail...
Thanks
Thanks
Here are the stock LS2 car throttle body pin designations:
A. TAC 2
B. TAC 1
C. +5v TPS Reference
D. TP1 Signal
E. Common Ground
F. TP2 Signal
Pin position for stock LS6 DBW TB:
Actuator Control Motor Harness:
A. TAC 1 (YEL, .8)
B. TAC 2 (BRN, .8)
Throttle Position Sensor Harness:
A. 5V Reference for TP Sensor 1 (DK GRN, .35)
B. Low Reference for TP Sensor 1 (PPL, .35)
C. TP Sensor 1 Signal (DK BLU, .35)
D. 5V Reference for TP Sensor 2 (YEL/BLK, .35)
E. Low Reference for TP Sensor 2 (WHT, .35)
F. TP Sensor 2 Signal (PNK, .35)
Pin Position to convert LS6 DBW for LS2 Throttle Body:
A. TAC 2 (BRN, .8)
B. TAC 1 (YEL, .8)
C. 5V Reference for TP Sensor 1 (DK GRN, .35)
D. TP Sensor 1 Signal (DK BLU, .35)
E. Low Reference for TP Sensor 1 (PPL, .35)
You will have two wires left over from the stock throttle position sensor wiring harness, wires D and E. Secure these away from each other and tuck away, they are not used.
A. TAC 2
B. TAC 1
D. TP1 Signal
E. Common Ground
F. TP2 Signal
A. TAC 1 (YEL, .8)
B. TAC 2 (BRN, .8)
A. TAC 2 (BRN, .8)
B. TAC 1 (YEL, .8)
