418 in C5...a few questions
I'm in the middle of installing a 418 in a 99 C5. I have a few questions regarding this install.
Knock sensors - I have the extension harness and see where the knock sensors go but the holes are not the correct size for the LS1 knock sensors. Do this have to be drilled/tapped for them to fit?
Cam sensor - Do i plug it into the 6" harness mounted on the front cover or do I get rid of this 6" harness on the cover and plug directly into the cam sensor itself?
RH Motor Mount - The RH motor mount that bolts to the block doesnt sit up flush against the machined mounting points. The bracket hits on a portion of the block that sits out slightly for a bolt hole near where the a/c compressor bracket mounts. Does the mount have to be modified? I dont want to grind away part of the mount in fear that it may weaken it. Anyone experience this before?
PCV system - New engine has nipple from front of valley cover whereas old engine didnt have this. I have bolted on the stock valve covers. Do I use the stock plumbing for any of this or how exactly do I route it? I dont have a catch can for this engine either. Should I need a catch can?
Thanks in advance!
Josh
Thanks in advance!
Josh
I found the answers to a few of my own questions...
The knock sensor holes in the LS3 block are an M8 and need to be drilled/tapped out to a M10x1.5 to accept the LS1 knock sensors.
Still havent found the answer about the cam sensor....
The block has to be clearanced for the RH mount to fit. I chose to not clearance the mount itself because I didnt want to weaken it.
For the PCV system, I left the valley cover nipple plugged, capped off the front nipple on the front of the passenger side valve cover, and installed a breather on the oil fill neck.
The pic is of my motor mount, that i machined.
