where to put gauge sensors ?
Oil pressure for the stock harness comes off the back of the engine (think where the distributor would go on a SBC). Your 06 PCM might actually look at it and watch it for something, I dont know, so you might want to consider leaving it functional. Its also a metric thread (12mm??). Again adapters are available. What lots of guys do is down by the oil filter like you mentioned is a small cover with 2 bolts holding it on to the pan. Some are drilled and tapped and have a sender already there, some are cast and undrilled. You can drill and tap it for 1/8" NPT and put a pressure sender there. Also, a third option is if you run a remote oil filter setup its easy to set one up. A fourth option I seen was removing the plug in the oil galley on the drivers side at the front of the block and putting a sender there. That is also metric there. Im sure it was a vendor for this site that posted that one on there site, but I cant remember which one.
Volt meter, shouldnt be too hard to hook up. Im not sure which pin to use off the alternator, it might vary based on the alternator you use. Cant help you too much on that one.
Lots of options.
