L92 engine harness
Old Sep 15, 2009 | 03:59 AM
dimetweaker's Avatar
Default L92 engine harness
Im switching to a cable throttle body and eliminating the vvt on my l92 and was curious if anyone could recommend a good harness/ ECM from another year/model vehicle.
Old Sep 15, 2009 | 11:39 AM
pillagenburn's Avatar
what vehicle is it going to be going into? and why are you removing the VVT/drive by wire/e38 ecu?
Old Sep 16, 2009 | 01:41 AM
its going into a 1984 s-10. When I bought the motor it had a little collision between the #1 piston and the intake valve, so it needed valves, push rods... I just decided the VVT wasnt something I wanted to deal with. This will be my first turbo build and I wanted to eliminate any additional variables for right now. Since I dont know much about the VVT, I dont even know if everything for it is there, so im just going to a standard cam/ timing set up. A turbo 6.2 liter will do everything I need it to without the vvt. I have 2 of these motors and I intended to leave the VVT in place when I swap the second one.
