650 Hp headers- What size pipe?
Old Sep 24, 2009 | 04:53 AM
Ls2 cruiser's Avatar
Default 650 Hp headers- What size pipe?
What size engine pipes and twin exhaust would you need for a motor that puts out 650Hp N/A at the crankshaft? Cheers Russ
Old Sep 25, 2009 | 10:16 AM
abbaskhan's Avatar
1 7/8 to to 3in
Old Sep 25, 2009 | 04:08 PM
tals7's Avatar
i use 2in arh to 3.5 collectors to 4in over the axle mufflex with magnaflo muffler.made 658hp on superflo dyno.
Old Sep 27, 2009 | 03:32 AM
I am buying the Trickflow 225cc CNC ported 65cc comb. chamber heads. These heads flow 259cfm on the exhaust at .600 lift. I have found a graph on the net under David Vizards exhaust article and according to this graph it is something like 2 1/8" primary. Then because I am running 8 psi boost the pipes could even go bigger. My ls2 is still 364 cubes. Does anyone have any other thoughts on this? Cheers Russ
Old Sep 27, 2009 | 06:37 AM
tals7's Avatar
for your combo 1 7/8 with 3in collecters sounds real good imo.
Old Sep 27, 2009 | 09:00 AM
Tals7, thank you for your help. What about with the FI - could I go to 2" primaries to let the flow out? Cheers Russ
Old Sep 28, 2009 | 06:33 PM
Dustin@PremierAutosports's Avatar
You could, but I think 1 7/8 will be plenty.
Old Sep 28, 2009 | 06:58 PM
2000_SS's Avatar
Go 2" and be done with it. i've got 2" Kooks on my 454 and it's NA. a boosted 364 will move the same or more air than my 454, the more pipe you have, the better. i would AT LEAST go 1 7/8" stepped to 2" witha 3.5" collector, but that's just me. the car would still run fine with 1 7/8" x 3", but i'd go bigger.
Old Sep 29, 2009 | 05:47 AM
Gordon0652's Avatar
My 440 will have KOOKS D-Port 2" to 3.5"
Old Sep 29, 2009 | 07:23 AM
z28mccrory's Avatar
We used to run a 2000+hp outlaw car (400ci w/F3R blower) and ran 1 7/8 headers...
Old Sep 29, 2009 | 02:22 PM
tals7's Avatar
you could use 2in headers but might lose a little down low with small cubes.when we dyno tested my motor we tryed stock ls7,1/34,1/78,2in headers mine just liked the 2in ones.i will tell you there was not a huge diff between them all.i made 653hp on the stock ls7 quads.
Old Oct 7, 2009 | 09:21 PM
spooky_zo6's Avatar
Thers two ways to go 1 7/8 stepped 2.0inch or strait 2.0 inch in my past stepped headers make more tork....and tork is king..
Old Oct 15, 2009 | 04:20 AM
Thanks fellas for all the info. It gives me something to ponder over. cheers Russ
Old Oct 15, 2009 | 04:49 AM
Jeff Smith's Avatar
I using Kooks D-shaped 1-7/8"-3" in my Ls2..Nice sound
Old Oct 16, 2009 | 08:15 AM
KRAZY K 2000 TA's Avatar
1 7/8 to 3 is sufficient. i am going 1 7/8 to 2 stepped to 3 1/2 then to 4 inch y to four inch mufflex system.
