Header primaries too large for my set up?
Old Oct 20, 2009 | 01:21 PM
ss.slp.ls1's Avatar
Originally Posted by John@Scoggin
Well then it should not be an issue. That is what i meant. Sorry just got back from lunch trying to catch up. Did not see you note that you were using the other K member
Oh, sorry yeah I will be using a LS1 k-member and LS1 front acc's. I thought that it was a requirement as an LT1 k-member wouldn't work.
Old Oct 20, 2009 | 01:23 PM
jmilz28's Avatar
Originally Posted by Hard Core Z28
He could make more power with larger headers with the cost of everything down low. Put 1 7/8-2 on your car and it will be a pig. Go right ahead.
Based on what?? Someone is buying the old wives' tale. This absolutely does not apply to LS motors.
I have 1 7/8 ARHs on my bone stock LS1 and she makes plenty of torque, including over 300rw as soon as the dyno starts measuring.
Get you a good tune and you will gain everywhere. This is especially true since you are putting together a pretty stout combo...let it breathe.
Fitment may be an issue, may not be. Each car is a little different when it comes to 4th gens. 1 7/8 and up, some will need massaging/notching, some slide right in. Make sure you get poly motor mounts.
Old Oct 20, 2009 | 01:37 PM
ss.slp.ls1's Avatar
I have poly everything.
So is 750 shipped a "steal" for Kooks 1 7/8" x 2" SS headers?
Old Oct 20, 2009 | 04:16 PM
2000_SS's Avatar
$750 is a GREAT price for the stepped Kooks. My 1 7/8" NON-stepped (that i never got to use, traded for 2") were close to $800. The steeped headers are WAY more expensive due to the extra larger diameter tubing and manufacturing time. $750 is a steal.
