Header primaries too large for my set up?
You don't absolutely need the stepped header, although it will likely help your curves a bit on the rollers. Unless you're getting a STEAL on them, the 1 7/8" will take care of you perfectly!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
u can see where im going with this.
the basic 1 7/8 are fine.
