need help with high performance alternator !!
Old Oct 28, 2009 | 01:32 PM
corvette_uae1's Avatar
Default need help with high performance alternator !!
hey guys well
i got a 6.0 lq9 engine with magna charger supercharge my stock alternator its not working any more
and i want ur suggestions on what high performance alternator should i go for with a good price , my second qusetion is
ive seen some types with 200 amp and some with 160 amp i dont know how much amp is the stock alternator and how much amp should i go for a high performance engine ?
regards
Old Oct 28, 2009 | 05:17 PM
LS6427's Avatar
stock size alternator is all you need.
Old Oct 30, 2009 | 10:51 AM
thanks ls6427 for the repley and ur help
Old Oct 30, 2009 | 01:07 PM
LS6427's Avatar
I was being serious. My 427ci, with an underdrive crank pulley, A/C blasting, headlights on at night, and my 1,000 watt amp with my 12" woofer cranking...at idle....is perfect. I have a PepBoys alternator, stock OEM output. My volts never budge, never drop, nothing gets dim. Perfect no matter what I do.
If your charging system is healthy, stock size can do it all.
