Custom PCV/TB/Valve Covers Question
Old Dec 3, 2009 | 08:13 AM
Tobynine9's Avatar
Default Custom PCV/TB/Valve Covers Question
I have an LS2 shortblock with Patriot 243 heads underneath a FAST 92 with an older NW 92 TB. The valve covers are carbon fiber and have only one breather/tube port on the rear of the driver's side. The oil filler is on the front of the passenger side.
Do I need to route a hose from the threaded port underneath my thumb in this picture over to the breather port on the driver's side valve cover or can I just plug it and stick a breather on the cover?
Thanks!
Old Dec 3, 2009 | 05:13 PM
Nasty N8's Avatar
Are you using the factory PCV on the valley? I would either run it to the TB or to a catch can with a filter on it if you run a filter on the cover you will get oil spray on the covers think old school chevy with a sock around the breather.
Old Dec 4, 2009 | 07:23 AM
Tobynine9's Avatar
It's got the stock LS2 pcv on it inside the valley cover. That's how the hose was routed on the stock intake, just behind the throttle body, so that's how I put it with the FAST.
