Slicing pounds
Old Dec 3, 2009 | 05:54 PM
intenseblue's Avatar
Default Slicing pounds
What are the pros/cons of lightening a rotating assembly? I know reduced rotational mass frees up power but what are the downsides?
Old Dec 3, 2009 | 06:20 PM
OUTLAWZ RACING's Avatar
Not sure but I think with a lighten flywheel you will have a on off feel for the clutch. I had that issues with the findanza flywheel with a ls6 clutch and asp pulley. But my motor would rev faster and climb in the power band faster. But I would guess its a plus to have the lightest rotating assembly for na Im not sure on the durablity of it. Also compression has a big affect on throttle response
Old Dec 3, 2009 | 06:34 PM
That's my thoughts also and I'm wondering why more people don't go for lighter parts such as TSP which use Eagle parts as opposed to say a Callies crankshaft which weighs considerably less.
Can someone explain how balancing works?
Old Dec 4, 2009 | 04:48 PM
GSXRofDFW's Avatar
A lighter flywheel and rotating assembly can cause stalling problems because there isn't enough mass to keep the engine running at times. Other than that I personally love a lighter assembly and flywheel. The RPMs fall off really fast between shifts and the car seems to engine brake when the throttle is closed much easier than a car with a heavy flywheel.
