TFS245's or All Pro's
What do you think? I'm looking for some input here.
LSX Nova
We offer our 457 with TFS 245's on top, 9 second combo !
You have a great set of heads on there now, yes the All Pro flow more and the intake option might flow more as well so there is power to be made but it will come at a maximum cost. I have All Pros on my personal car, as stated the rockers you need to run wiht them are $1650 alone from Jesel less from T+D but longer wait.
Changing to All-Pros won't do much because the weak link in your set up is your intake. We used to be restricted because of cheesy heads....now we have awesome heads and the same cheesy plastic intakes. Or sheet metals which suck on the street and still don't make much more power than the plastic intakes.
Go here, scroll down to the appropriate LSx intake. $3,600. Bolt one of these on and your 454ci will wake up like you never dreamed possible.
http://www.extrudabody.biz/servlet/t...its/Categories
The GTO drivetrain eats the power (15%). My goal is 700 crank hp(est) on 93 pump gas and N/A......call me crazy.
I've done more to the engine since Mike tuned it and it does need a sd tune. I believe I'm running out of air @6k or out of maf.Torque isnt a issue, at 45mph in 3rd it will liquify the tires........
I think you're going down the right path though. The GTO drivetrains ARE more parasitic and a re-tune in SD might be all you need on a different dyno to see 600+ rwhp. i started my build with 600 as the goal. I had Tony Mamo port a FAST 92 for my HKE-built 454 though. I asked him about going 96mm and he said it wouldn't yield any results. I can't remember the exact numbers, but a 454 at WOT pulls "x" cfm and the 92mm opening flows way more than that. You might consider 2" headers or, i dunno...a F1-R
My camaro's drivetrain is not like the GTO's, but i DO still have a 9" with 4.11's, which will eat quite a bit of power. I'm waiting for my Meziere pump to show up for the first start-up. Keep an eye on my build thread (in sig) for updates. Good luck
