LS3 Throttle Bodies
I don't need anything pretty or special right now, just something cheap to get my build going. I go to school so the budget is tight. I just want to find a cheap OEM TB.
End Rant/
DM
there are no GM 90mm cable TBs. GM switched to DBW for LS2+
I am looking into a 95mm Janzter Motorsports unit, TPIS 90mm and a 90mm FAST. Just waiting on replies from the sellers.
DM
DM
I measured this up last week to try and fit up a 102 on the same intake and have decided to go with a 92mm NW instead.
cheers
cheers
cheers
In installation manual for new ls376 engines says that maf must be installed in 100mm intake tube...Why says 100 and not 93.5mm? Do we need some adapter?
If you put the MAF in a smaller or larger diameter tube it'll mess up the air fuel ratio and spark advance delivered to the engine unless you re-calibrate the sensor with tuning software.
