Self-ported FAST 92mm pics. before/after..
It might just better to add "ported" FAST to your sig, but not really port it, and call it a day...
I also know that there are a lot of mismatched ports, but the FAST makes power on all of them still.
It looks nice though! You should test it out and tell us how it actually does!!
But one thing i can say, i would not have left it alone doing the porting for there are so many that say that porting it right makes power, and have acctual gains (dyno).....
so i did , and did it my self for there are no one doing it here where i live (Iceland)
And for the head´s edges that i grinded a bit to match the FAST , it was either that or epoxy the intake´s runners, but it was easyer for my to do the ginding , i don´t know the epoxy method, so hopefully i did not damadge anything like some people claim you do "if you **** whith TFS heads"....
I´ll say it must be better flow whith no edges then whith edges at WOT, but that is just me...
All things i did where things i would have done in matter of time for they must make power "I THINK" but then again that is just me.....
Baezi
or there is a vaccum leak....
good luck
Baezi
Now, however, i'm only using manifolds ported by Tony Mamo. Yeah, it's pricier, but the difference in his work and everyone elses (that i've seen) is undeniable.
Good luck with your car, let us know how it turns out
But then again, I tell myself, you have to remember that an engine is a vacuum so its always wanting to draw air in, which means that even though there are these, we'll call them "hinderances" in the way, ie, the metal walls blocking "smooth" airflow into the head, the turbulance caused COULD possibly help the engine draw more air in at a quicker rate, like plugging the end of the hose so much with ur thumb to shoot the water further and harder, we all have done this b4. Rather than it coming out slowly or only efficient at max rpm. So I get where Pat G is coming from by saying I hope your engine likes the porting because he is right, not all engine are built for max flow at max rpm and even then, everyone has a different max rpm anyways...
Whoever REALLY knows about this stuff could clarify any of this, that would be cool because I am trying to understand this is my head as well. Thanks
To the OP, nice port work BTW! Takes patience and a steady hand for sure!
Went at the track last week and picked up 4 miles in trap speed but on a rich tune this time 11.9-12.1 at WOT
but i was not running slicks now so i didn´t get better time, but will go again when the slicks have arrived and after i lean it out....
but raw 4mph is damn good after my winters mods on N/a motor...
Baezi
