I need injection help !!
Ok, I'm new to the LS2 game and need help. I have an LS2 '06 Corvette long block that I am finishing out to go into my Panoz road race track car. Presently it has an injected sbf 302 with a Tremic 3550. Anyway, I would like to run fuel injection on the LS2. I have a Victor jr intake set up for fuel injection rails, but no fuel rails. Now for the stupid question, what throttle body should I get, what computer (can I have the Ford computer reporgramed?) should I get, is there a package or a list of parts to make my life easy? I know is sounds like a very basic question for fuel injection experts, but my past track cars have all used carbs, so mixing and matching with the fuel injection is very new for me. So, please take it easy on this newbe, I really want my LS powered Panoz to show those Ford powered guys what a real engine should run like.
Thanks
Thanks
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
After thinking it over, I think I should really make it easy on myself and just go LS2 manifold, injectors, computer, etc. I would think I should be able to get a complete package like that from Corvette or GTO junk yard guys. Do you guys know any that specialize in those cars?
Hey Ducky
Sounds to me like you need a set of Fuel Rails,a set of 42lb Injectors(You need to match the injectors with the Rails low or tall type depending on your fuel rail brackets)and an Accufab 4150 style throttle body.Then the Fun comes,If you are running a Race Car you need a good Computer System to Run everything.The factory system is not going to cut it in a Race Car.Make the investment & go for a FAST or an Accel or a Big Stuff3 Setup.They Come with the entire LS2 Harness and all the right plugs.You can learn how to program these systems a lot easier than fighting a factory system.
Call Dale Cherry at Injection Connection in PA. he can set you up,he knows this stuff,I just saw a Miata Road Race Car at his shop with an LS2
Good Luck
Good Luck
