Cost to sleeve and LS2 block.
haha. Oh well maybe you'll make it out to MIR the same time i do so i can see it. Otherwise i'll have to hope to run into you somewhere around NOVA. The 427 should be nasty, congrats and goodluck. The Best V8 Stories One Small Block at Time
As for the larger bore-the 4.00 bore greatly shrouds the l92 valves.We have picked up 20rwhp going from a 6.0 to 6.2 block with all other things being equal.Going to a 4.125 bore should help this even more.
The last but not least thing to consider is the sleeves.They are much thicker and stronger than the factory sleeves-they will keep a much rounder bore when cylinder pressure is introduced,making for better ring seal and increased power.
It'll fit, keep whackin it!!!!
