Cost to sleeve and LS2 block.
Old Dec 23, 2009 | 05:50 AM
WKMCD's Avatar
Default Cost to sleeve and LS2 block.
Just thinking out loud here. What's the cost to sleeve and LS2 block to run a 4.125 bore?
Old Dec 23, 2009 | 06:05 AM
69LT1Bird's Avatar
Cool, this should be good, Kevin is bored and wants more power!!!!
Here is one place on line to give you an idea.
http://www.cdpautomachine.com/ecatalog/Sleeves.html
You can get a LSX block for $2000 and bore it to 4.100"
Old Dec 23, 2009 | 07:06 AM
WKMCD's Avatar
LOL - I want to stay with an aluminum block. Haven't seen the al LSX block yet but I know it's coming.
Old Dec 23, 2009 | 08:19 AM
Shawn @ VA Speed's Avatar
I charge $1600.00 to dry sleeve an ls2 block to 4.125 bores
Old Dec 23, 2009 | 09:09 AM
WKMCD's Avatar
427 =
Call me.
ducky1's Avatar
Default Sleeve block
If you want a bullet proof big bore block, give Steve a call at ERL Performance. They are not cheap, but you will get a killer block, ready to take on all the hp you can throw at it. Their web site is at erlinc.net, then spool down to ERL Performance. Very impressive re-engineering of the strength of an LSx aluminum block.
Old Dec 23, 2009 | 11:46 AM
WKMCD's Avatar
You make is sooooo easy to give you money.
What the hell, let's do it!
Old Dec 23, 2009 | 11:53 AM
sixt9er's Avatar
Just curious to know what a "dry sleeve" is and the process in which to get it done. Does this process make an aluminum block "stronger" than it was in stock form? Didn't mean to jack your thread WKMCD, but I am considering doing such a thing to my new LS6 block.
Old Dec 23, 2009 | 12:20 PM
69LT1Bird's Avatar
I can't wait to see what you come up with this time.
Old Dec 23, 2009 | 12:30 PM
ducky1's Avatar
ERL actually machines out the sleeves and small supports, than welds in heavy supports between the intake side and the exhaust side of the block, then machines the block to take their stronger liners. The heat treats the block, decks it and line bore. Check their web site. Good people. You know what they say. "You dont always get what you pay for, but you always pay for what you get"
Old Dec 23, 2009 | 01:14 PM
WKMCD's Avatar
This is "just" a street toy. I'm sure it will be fine with Shawn paying the same attention to detail that he does all his builds including Phil Thomas's 2500hp LSX Mustang. Thanks for your precious advice anyways.
Old Dec 23, 2009 | 01:37 PM
allan808's Avatar
for a few more hundred you can get a lsx race block...and why is sleeving so expensive?
Old Dec 23, 2009 | 01:45 PM
WKMCD's Avatar
This is in a vette. Don't want an iron block up front.
Old Dec 23, 2009 | 03:55 PM
Fireball's Avatar
cost of the sleeves is a good majority of it
Old Dec 23, 2009 | 03:57 PM
allngn_c5's Avatar
Damn, Kevin !! How long you had your setup running perfectly and already want more power. LOL, I'm in the same boat but money isn't great like it was so I am stuck dealing with what I got. Poor me, lol. Good luck on your project.
Old Dec 23, 2009 | 04:19 PM
sleeves are $1000.00 and it take a good bit of machine work to cut out the old sleeves and machine for the new ones-forget the cost of the $250,000.00 machine to do it.
Old Dec 23, 2009 | 04:23 PM
edcmat-l1's Avatar
Can't ya just whiddle em out with a dremel and knock in the new ones with a rubber mallet?????? It'll fit, keep whackin it!!!!
Old Dec 23, 2009 | 05:06 PM
WKMCD's Avatar
Old Dec 23, 2009 | 07:46 PM
ducky1's Avatar
My grand dad said, "boy, don't use force, get a bigger hammer".
Old Dec 24, 2009 | 09:54 PM
ringram's Avatar
4.25" crank and 4.185" bore mate. You know it makes sence!
Shaun and Ed will do it
