Thermostatic Oil Cooler Adapter
The great thing about these adapters is that you don't need to run an external thermostat. This means you not only save some cash and need fewer lines and fittings, but your engine will receive oil quicker during startup since the oil cooler is bypassed directly at the block. If you plan on installing an oil cooler this is the perfect solution.
For more information visit http://www.improvedracing.com/product_info...?products_id=33
EDIT: The distributor made a mistake in pricing and the new MSRP is $174.50. We adjusted our price accordingly. Sucks, I know.
No, our baffle doesn't work with the GTO pan. We have one for the Holden front-sump pan, which is identical externally, but different internally so the baffle doesn't bolt up. One option is to purchase a Holden pan. It will bolt right up and we offer them brand new including the trap-door baffle and pickup, gaskets, crossover tubes, etc for $299.
This adapter should bolt right up to the LS7 pan. Where is the stock oil cooler plumbed to?
Neither the C5 nor the C6 had a thermostat, so this would be a very valuable addition for those cars, especially if you drive in cold weather.
I can't believe they didn't come with a thermostat from the factory. Mocal actually developed this adapter for GM, but I guess they didn't use it because they decided to go with the air/water cooler instead.
Jimbo
The sensor location is at the angled protrusion on top of the adapter, similar to the stock location. There is about 3.5" of clearance between it and the block.
Thanks for the quick response. I'm running a DeWitts radiator with the left side EOC and it takes way too long for my oil pressure to come up with the set-up I have now. (Lingenfelter style adapter and 10AN lines). This adapter will cure that problem I'm sure. Will order soon.
Jimbo
Jimbo
