Any tb porters have experience with the dbw 87mm?
I've searched all over the place and found a bunch of conflicting info on porting the 87mm tb in particular. Seems a majority claim no real dyno gains and many more claim idle issues after porting. I cant see how a good port job that doesnt mess up the blade function or the blade seat area can possibly cause problems but... one never knows. So I'd appreciate to hear from anyone whos worked with these and what issues/success you had. Thanks
Yeah thats pretty much what I keep seeing is dont bother but asking cant hurt. Theres such a huge chunk of aluminum right in the airway path though that has me baffled as to why its there and even more importantly why porting it out wont make gains. LS1 tb's have barely any obstruction in stock trim compared to these 87mm ones.
Does anyone have a pic of the ZR1 throttle body inlet? I'd like to see if its exactly the same as the truck version with the big chunk in front of it. Thanks again
Yeah thats exactly what i would do too. My thoughts at this point are to get the thing up and running and port it afterwards. Being a swap with sooo much going on already and considering how simple it is to pop the tb off at anytime I figure I'll get into that after Im working well. Afternoons job type of a thing or if I could find someone who does corre exchange that might be on option too.
I port them quite a bit. No issues as long as it is done right. I've heard from some custmers that idle was kind of wierd if they did not disconnect the battery or pcm fuse. Ideally you want the pcm to start up fresh with the ported TB and I always recommend it.
Gains in throttle response are always there after porting. Gains in hp and tq are only there if the engine was restricted by the TB.
