Bought LS7 crate engine, where to find information on all hoses?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hi,
I have an LS7 crate engine that will be used in my AC Cobra replica. I have a good diagram showing how to connect all the electrical stuff but nothing on all the hoses. Appart from the more obvious stuff like fuel lines etc. there are several other hoses going to and from the engine if you look at a Z06. Any whay to get hold of a workshop manual or something that could help me?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Thanks,
Thanks,
The only hoses you will need are the PCV hoses. Search under PCV and you will find a lengthy discussion on this topic.
I dont think you will be using the evap emmissions sytems so those will be removed.
Are you planning on using the drysump system or converting to wet.
Ok, thing is that I really don't know what or which connectors are for the PCV
But I will search and have a look
Same goes for the evap emission stuff but I know that I do not need to use it but I guess I maybe need to plug some hose connectors then?
I will be using the drysump, there are two hose connectors on top of the drysump tank, are those only for ventilation?
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Found a few drawings in this thread:
https://ls1tech.com/forums/generatio...cv-system.html
This forum is exellent
I will have another look at my engine to see what else I need to sort out.
Thanks,
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks,
