C6 LS2 radiator removal / transmission oil cooler lines?
I've searched on this forum and haven't had any luck.
Can someone please tell me if you have to use the quick disconnect tools (J-41623-B & DT-47730) to remove the transmission oil cooler lines from the radiator, or can you just unscrew the fitting from the radiator and leave the quick disconnect fitting attached to the lines.
I got lucky & purchased the DT-47730 from Ebay but so far haven't had any luck removing the 1/2 lines. I hate to have to buy another specialty tool for the 3/8 inch lines if I don't have too, especially since it's about $75.00 for this tool.
Working on my head & cam swap on my C6. So far it hasn't been too tough, but this radiator is becoming a pain.
Any help will be appreciated.
