What the H#$$ is that noise in my intake!
I am concerned about the DOD delete situation. The company that sold me the engine said that they had removed all the pieces to delete DOD and recommended that I have the feature turned off by my programmer. I did but this noise is very scary and I don't know what else it could be. Even if it was not deleted it would not engage sitting there in park idling would it?
Any suggestions would be greatly appreciated. It's beena a long hard job getting this going and is sucks to sit here now with nothin!
If you dont feel up to that then run it at a slightly higher RPM around 2K or thereabouts for a few mins and it should quiet down. If it doesnt within five mins....
Mechanical parts don't heal. If the lifters weren't full of oil they would make noise first then quiet down after pressure arrived not the other way around.
If it was the sensors it would not run perfectly for even a minute then cause backfiring inside the intake manifold. The problem is repeatable and consistent.
Houston we have a problem.
Theres nothing any of us can say that will magically make the noise go away. The choice is yours and I truly hope it turns out to be nothing major.
Good luck
The engine seller had removed the AFM/DOD valley cover and replaced it with a non AFM/DOD cover thinking that and deleting the feature in the PCM would delete the option. WRONG.
The blank off plate plugs the passages that would normally allow oil to flow back into the engine and after about 1 minute enough pressure is built up to collapse the lifters on the DOD cylinders. This is and the PCM program running in 8 cyl. mode still firing and injecting fuel into those cylinders with collapsed lifters caused the explosions in the intake manifold.
The key was to put back the stock AFM/DOD valley cover not plugged into anything and leave the feature deleted from the PCM is all it needed.
No Matter what you have read, Deleting AFM/DOD is as simple as unplugging it in the rear of the valley cover and deleting it from the PCM program.
The power this motor exhibits with just free flowing exhaust and intake with a performance tune is astounding! I can't wait to get it out to the dunes!
Plus at some point might makes right and those dang spring lifters "apparently" dont hold up to different cam base circles/lobe designs etc.
I think DOD is marketing BS and barking completely up the wrong tree myself.
Dont be afraid of HEAT its your friend for efficiency. Just need a new special sauce LOL
