LS2 PCV Routing
Thanks in advance!
https://ls1tech.com/forums/general-m...l#post13439420
Is the PCV "valve" on the LS2 / LS3 an actual valve in the traditional sense? I am trying to determine if one is working properly.
Most systems utilize a ball-type check valve and are functioning properly if you can suck air through but not blow air out of the attached rubber line.
Does one check the LS2 / LS3 PCV's mounted on the valley cover in the same fashion? If not, how can you determine if it is functioning correctly?
