Rebuild LS1 or drop in LQ4
-You will need your oil pan and intake off of the LS1 - the intake off of the trucks is too tall and the oil pan doesn't fit the F-bodies.
-The TB coolant lines are different than the LS1. You will have to buy about 6 inches of rubber hose and slightly (and GENTLY) tweak the metal coolant line to clear the intake.
-I had problems getting the truck coils to clear the small evap thingy on the fuel rail (correct me if that isn't what its called lol)
-The oil filler neck that was on the trucks is too tall and you will need one from an F-Body.
-The oil pressure sending unit that comes on the truck engines is a 3 wire and not a 1 wire like the LS1's so you will need one off of an LS1.
-The alternator bracket will only be held in by 2 bolts unless you tap the other one. I did not, and I haven't had any problems.
-You may want to use the pulley off of the truck power steering pump. It is metal unlike the cheap plastic that the F-bodies use and it is the same size, just more durable and you don't have to worry about it cracking when you hammer it on the pump.
-Make sure you keep all of your accesories and brackets as I don't think the truck ones will work without modification. Also, you will need the crankshaft pulley off of the LS1 since the truck pulley won't line up with the rest of the accesories.
Some of the above may not apply to you but for me they did since I bought a complete LQ9 from intake to pan.
I was going to do a build thread and use all of the pics I have but I am too lazy right now to do a write up lol.
Usual size of the TB on the trucks was 75 or 78mm. I think all the ones with L92 heads had a 90. Though not 100% sure on that.
According to Wikipedia, the Tahoes came with 4.8's and 5.3's but that's what Wiki says. I'm sure someone on here will chime in who knows for sure.
It also looks like the Tahoe Hybrid came with a 6.0L but that was in 08 and on.
