Quick question about L76 accessory drive system
Old Jun 29, 2010 | 01:38 PM
qnitro's Avatar
Default Quick question about L76 accessory drive system
I have a L76 Motor I'm building for my 1975 Trans Am. I got a SMOKING deal on a S&P Billet accessory drive system( http://www.hotrodlane.cc/PDFFILES/ls-1tight.pdf ), comes with PS,Alt, A/C all the brackets and idler pulleys, BUT its for a LS1. So my question is, Can I put a LS1 Water pump, and accessory's with a LS1 Crank Pulley on a L76?? Will there be any issues??? Its a High mount Alt and A/C, So I wont have clearance issues.
Old Jul 9, 2010 | 11:20 AM
Jimbo1367's Avatar
does this have VVT or DOD? If so, you will have to loose the VVT as the waterpump is spaced out further from the block.
Old Jul 20, 2010 | 03:02 AM
qnitro's Avatar
yeah has VVT Im dumping the whole set up... Im going to go with a LS1 set up Im pretty sure
