243-799 heads
Old Jul 29, 2010 | 12:56 PM
cookseyb's Avatar
Default 243-799 heads
I'm tearing down a motor I bought out of a Trailblazer SS, one head is a 799 the other is a 243, according to info. I looked up they are the same, however after I cleaned them up the 243 casting is much smoother. I just dropped them off at patriot to have them reworked and was told they are the same dimensionality but the 799 was a sand casting. Has anyone else had this issue? BTW the motor had never been into as best I can tell. Bill
Old Jul 29, 2010 | 09:28 PM
redbadss's Avatar
Hmm, interesting scenario. Its hard for me to believe that GM would put two different casting numbered heads on the same car. I know it doesn't help your situation but all of my cars(6 GM and 1 Ford) have the same cast numbers on both heads. Sounds to me like the car might of had an engine problem and possibly had one of the heads replaced under warranty since both heads are essentially the same.
Old Jul 29, 2010 | 09:45 PM
burgers's Avatar
I have seen that on 2 -3 motors I have got in over the last year. Its more common than you would think.
Old Jul 30, 2010 | 07:28 AM
cookseyb's Avatar
I'm glad someone else has seen this. I wonder where the 2 different castings are made?
