Need info on MAF sensor with 90mm fast intake
Old Aug 3, 2010 | 06:39 PM
LS1&95S10's Avatar
Default Need info on MAF sensor with 90mm fast intake
Hey guys I need to know what is the best thing to do with the maf sensor when going to a fast 90/90mm set up i have a LS1 harness which has the seprate IAT and a stock 78mm maf sensor I have a Granitelli (I know its spelled wrong) which looks to be the same as stock size I dont want to have the 78mm restriction between the throttle body and the filter what is out there in the 90mm ID range that will work with my setup. The truck is a 02 S10 with a LS2 A4 MS3 cam mild ported Ls6 heads long tubes 3400 converter. So what can I use for a MAF sensor.
Old Aug 3, 2010 | 06:55 PM
69LT1Bird's Avatar
85mm full size truck MAF will get you closer and they are cheap. You can get a used one around here with low miles to test for about $35
Old Aug 3, 2010 | 09:27 PM
SweetS10V8's Avatar
Im running an 85mm MAF right now on my 90/102mm.
Old Aug 4, 2010 | 04:35 PM
LS1&95S10's Avatar
Thanks guys but does any one else know of any other options out there for my setup I'll go with the 85mm if there isn't any other options for me. Thanks
Old Aug 4, 2010 | 05:13 PM
69LT1Bird's Avatar
if you can tune.
100mm MAF
Old Aug 4, 2010 | 09:14 PM
SweetS10V8's Avatar
Yup, there are other options..
I also have a Halltech 102mm MAF and a Lingenfelter 100mm MAF too....
http://www.halltechsystems.com/product_p/hornet102.htm
http://www.lingenfelter.com/mm5/merc...gory_Code=C162
Old Aug 5, 2010 | 12:21 AM
03EBZ06's Avatar
If you have tuning software, you could set it up SD. For myself, I consider a tuning system as important as the mods I have, it not more. I'm not sure your MAF is really a restriction though. Don't forget if you add a new MAF, you are going to have to tweak the MAF data and tune it.
Old Aug 5, 2010 | 06:10 AM
SweetS10V8's Avatar
Luckily tuning the MAF is super simple!
Old Aug 5, 2010 | 04:05 PM
LS1&95S10's Avatar
Thanks again for the input guys. My Brother does my tuning with his wide band and HP Tuners, I know what ever I use it will have to be tuned for my setup. But how will the 78mm maf not be a restriction in a all 90mm setup. I was just wondering if they put a 90mm maf sensor stock on anything that will work with my setup without having to buy a aftermarket maf. And yes I have concidered going SD just trying to look at all options.
Old Aug 5, 2010 | 06:35 PM
SweetS10V8's Avatar
Thats why we are telling you about the 85mm MAF.
Old Aug 5, 2010 | 08:58 PM
LS1&95S10's Avatar
OK Sounds good to me I will see if I can find one and give it a try.
Old Aug 5, 2010 | 10:31 PM
LS1&95S10's Avatar
What year trucks have the 85mm maf
Old Aug 6, 2010 | 06:55 AM
SweetS10V8's Avatar
Im fairly sure its actually 1999-2007 (classic body style) They also came on some corvettes too.
Old Aug 6, 2010 | 04:34 PM
LS1&95S10's Avatar
OK will it plug right in or will i have to have a adapter does those have the IAT sensor built in.
Old Aug 6, 2010 | 07:50 PM
SweetS10V8's Avatar
IAT is built in to the 85mm
Old Aug 7, 2010 | 12:26 PM
LS1&95S10's Avatar
my plugin is for a 3 wire maf are you using the 5 wire plugin that goes with the truck maf if so can you tell me how to wire it up.
Old Aug 7, 2010 | 01:40 PM
SweetS10V8's Avatar
http://www.lingenfelter.com/mm5/merc...Category_Code=
