Odd question, 317 heads on a LS3 shortblock CR question.
Old Aug 19, 2010 | 08:45 AM
slow's Avatar
Default Odd question, 317 heads on a LS3 shortblock CR question.
What would the compression be on this combination.
Thanks,
Ryan
Old Aug 22, 2010 | 01:41 AM
Whistler's Avatar
Sawzall and Welder Mod
10.5:1 give or take.. depends on the gasket.
Old Aug 28, 2010 | 05:21 PM
SweetS10V8's Avatar
google compression calculator....
Old Aug 29, 2010 | 03:04 PM
Pwebbz28's Avatar
WOW!! You're so smart!! Perhaps he doesnt know the size of the combustion chamber. Go back to nut swinging on fast intakes.
Old Aug 29, 2010 | 09:03 PM
SweetS10V8's Avatar
Then Google "317 combustion chamber size"
Google's first link;
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Material: Aluminium
Part Number:
12572035
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
This is an issue of "teach a man to fish"
With any strange combination you simply need to do a little research if you want a decent answer. Because 1 of 3 things will happen,
1. Someone will guess (See post #2)
2. Someone will google "compression calculator" and do the work for him
3. We can help him figure it out. This wont be his last oddball question, research is key.
