GTO power steering pump in fbody ?
I replaced my F-Body PAS pump with an early Holden pump to suit my blower setup.
Early GTO's should run the same pulley offset as the F-Body. Later versions may not though.
Just check, if they run the large water pump and belt runs on the outer position, then you'll be fine
Although even if it was the inner belt position, shouldnt be hard to space the pump out to suit.
