LSX Block/Stock Manifold 5th Gen
Just sat the new stroker in the car (5th gen Camaro) and now discovered that the driver side manifold want bolt up,It's hitting the last 2 studs,cause of the 6bolt configuration on the X heads,Don't think shorties will help me,cause I've got a 3" pipe coming by the exhaust,(Turbo),any advice or knowledge on modifying the stock manifold would be awesome,Suck's cause I've already had everything ceramic coated...........Thanks in total advance
Take another look at the pics,The holes on the manifold are'nt the problem..Their actually bolted up,and pulled up as far as it'll go..The problem is the the manifold is hitting the back two studs on the LSX Block/Heads,Was hoping someone around the country thats on the board,has already dealt with this and will chime in,But I might be the only one running stock manifolds,and did so because of turbo setup,most people are putting headers on,but Thanks for looking....
Good news
I got it I got it die grinder with burbit just made a 1" saddle on the precise location.....Just flawless I knew I could id,and will share the pics with you guys tommorrow 4 in da morning comes early...........
