Sheetmetal intake porn
The chassis is from SRIII Motorsports based in New Lenox, Ill. Mike Stockdale is the owner and is a tremendous frame fabricator. I am getting ready to start a 1965 Corvette coupe project and I will no doubt use his chassis again....awesome product!!
http://www.sriiimotorsports.com/home.html
R/
Jeff
Mike has sold 4 of the new style frames since showing mine at Carlisile.
I was at the Tool & Die maker Friday, Ed had a stack of covers going
to the anodizer. Looked awesome.
For everyone else interested,
Mike Stockdale does steel cars also. Has a 59' El Camino in the shop,
LS motor with corvette trans axle setup. Also a 55' Chevy; LS motor,
Ford center section with IRS in back. Both cars on tube chassis.
Jim
Ring and pinion were cryo'd and micro polished, Toms differential spider gears, steel caps, posi unit, inner and outer axle stubs and billet pinion flange. Also running 3" chrome moly half shafts and drive shaft with spicer 1350 joints. It's about as stout as that D44 can get, but I'm sure it could be broken if you try hard enough
R/
Jeff
It's not bad for the valet tune
I'm hoping you can tweak a little more out of her with the new intake
See ya Friday.R/
Jeff
..... so I compensated it with more power to help offset the extra fat
R/
Jeff
R/
Jeff
That's still really light considering how heavy modern cars are getting.
