No rpm on tach, any help???
Old Sep 6, 2010 | 01:47 PM
2 fast 2000's Avatar
Default No rpm on tach, any help???
Alright I'm having a issue on my new install. I have a LS3 416 build. After install and hook up of everything I don't get a rpm signal on my tach or snap -on scanner. It popped up a cam sensor code, so I thought it was the new wirring extension that now goes to the front of the motor( because of the ls2 cover). But after running a new extension it changed nothing. Don't remember the code, but it was a 300 something. Sometimes it is hard to crank, but when it is crunk it idles fine and made realy good power on the dyno. My car is a 2000 camaro SS. The cam sensor is new, the wirring extension has been swapped out for a new one. Still no tach signal, what gives???? Anything else I should do?? The engine was built by LME and made awesome power, so I know it was put together right. I have no other walls to beat my head on, so what else should I look for or do?
Old Sep 6, 2010 | 02:39 PM
bene's Avatar
Trunion King
Cam sensor isn't plugged in or it's not getting any power. How do I know? Well I just finished my heads and cam swap about a week ago and I had the EXACT same problem.
Old Sep 6, 2010 | 07:24 PM
1madss's Avatar
Try swapping pins 1 and 3 on the cam sensor extension. I had the same problem a couple of weeks ago after my 402 swap. It's very common.
Old Sep 6, 2010 | 10:46 PM
Cool I'll try and swap the pins and see what happens.
Old Sep 13, 2010 | 03:27 PM
Orange Juice's Avatar
Same problem, I was not the mechanic but he found a pin had popped out of the pack at the back of the motor, only found after he took the intake back off.
Old Sep 13, 2010 | 03:29 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Definitely a cam sensor problem, or problem with the wiring to it. Like mentioned, swap the A and C wires on that extension harness, and see if that helps.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
