L92/L76 408 Questions
Then you need the turbo and piping I am using
Good luck and let us know how it goes.
I am sure you know this but just incase not:
You need to make sure your pistons have the valve reliefs that will work with the L92 heads. The intake valve is offset some. And also because of this you have to run the correct intake rocker arms. The LS1 exhaust rockers will work but not the intake rockers. All else should be the same.
