How much to mill L92 heads?
With untouched L92's & stock GM gaskets SCR would be roughly ~ 8.8:1
Goal is to get as much compression that I can safely get (supercharger setup).
I'm unsure about the deck height measurement (at XP Racings shop). Any general ideas on how far I can mill L92s to run a 229-236 .590/.600 cam while maintaining a decent ptv clearance? Thanks in advance!
FWIW, I ran those heads N/A and my motor was 13:1cr and we did not mill the heads.
You mentioned you wanted to run a supercharger.. you would think a higher CR and a supercharger would make for even more power.. works more like a bomb.. lol Supercharged motors actually us lower CR and then adjust the other factors involved (fuel, timing and air)
You have to remember that the supercharger is forcing a larger volume of air into the cylinder so getting it out becomes very important, therefor you would need to increase the injector size to add more fuel to the air, port the exhaust side and add a free flowing exhaust to see good power with the CR you have already..
I also think I read the same thing about the piston notching is you shaved the heads...
Not to hijack this thread but my 6.0 L96 only has 2 miles on it and I just changed out the truck intake for a LS3 intake and I noticed this little machining flesh on all the intake ports..
