L92 swap into an fbody, startor ??
Old Oct 12, 2010 | 03:47 AM
BLOWN SS/T's Avatar
Default L92 swap into an fbody, startor ??
I have a 98 ls1/a4 and I'm going to be doing a 6.2 l92/m6 swap, I have the startor out of the l92 which came out of a 08 caddy escalade.
Wondering if I need to use the startor out of my ls1 or will the one out the l92 work? I tried the l92 on the ls1 and vise versa and they bolt up. The one out the l92 is a little different design, had a bigger opening for theeth.
Was considering selling it and the alternator out the caddy, but thinking about holding on to the startor. The alt from the 6.2 is a 2 bolt design and is alot bigger then the fbody which has 3 bolts.
Old Oct 12, 2010 | 10:56 AM
-TheBandit-'s Avatar
I would use the L92 starter, but either would probably work.
Do you have any pictures or dimensions comparing the alternators sizes?
Old Oct 12, 2010 | 11:03 AM
BLOWN SS/T's Avatar
I can email the pics, if u want to post them???
Old Oct 12, 2010 | 12:39 PM
That would be great. I'll PM my email address. Thank you!
Old Oct 12, 2010 | 12:58 PM
1lejohn's Avatar
Match the starter to the fly wheel that you are going to use.
Old Oct 13, 2010 | 05:39 AM
Unertl42's Avatar
Exactly what I was thinking
Old Oct 14, 2010 | 09:34 PM
onefastrx7turbo's Avatar
I am doing the exact same thing to my RX7. The L92 starter bolted right up and as far as I know they both have the same teeth count. Is there a reason why the L92 starter won't work with the T56 and the LS7 flywheel?
Old Oct 15, 2010 | 03:48 AM
BLOWN SS/T's Avatar
Idk, I don't see an issue, if the a4 and m6 starter are the same then I think this starter will work. I think it might just be stronger than the fbody starter, looks alot more sturdy. But I'll be testing it out on a stock t56 flywheel and clutch, then switch to an ls2 flywheel with ls7 clutch. I emailed pics of the two starters to "the bandit" hasn't posted them yet. Anyone want to post them for me? I can email you pics, I'm using my phone or else I'd do it.
Old Oct 25, 2010 | 06:36 PM
litle88's Avatar
any new news?
Old Oct 27, 2010 | 01:07 PM
pillagenburn's Avatar
I used a m12 t56 out of a 2004 GTO so I used a starter out of a 2004 GTO.
