GMPP LSX L92 vs standard L92.... deck/strength
I have done some research and cannot find a definitive answer
are the LSX L92's deck thickness any thicker or more robust than what a standard L92s deck thickness/strength is??
They state they are 5/8" thick but some say they really are not any different than the standard l92 other than the 6 bolt casting
just wondering if it is worth the 2k for a set of these heads if they will be more robust with boost than the standard l92.... or if i should just spend the 3k for something like the Mast heads
I do not want to switch to a cathedral port because i have my L76 manifold set up the way i like
any input is appreciated
