LS6 intake VS LS3
Old Nov 6, 2010 | 10:47 AM
first gen fan's Avatar
Default LS6 intake VS LS3
I want to change my TBSS motor intake to a car intake setup. I have been looking for a Ls6 intake but in the pics they look like a rect port setup instead of the cathedral port. If they are rect port and people are putting them on LS2's then why will a LS3 intake not work on an LS2?
BTW I am installing a TBSS LS2 into my 69 chevelle which is why I want to change to the car setup.
Old Nov 6, 2010 | 11:15 AM
C5kid's Avatar
They are cathedral ports on teh LS6, they are more rectanglar looking then the LS1 for some reason.
A LS3 is square, and will not work on cathedral ports. Ppl switch over to the LS2 because of the bigger throttle body.
Old Nov 6, 2010 | 01:39 PM
redbird555's Avatar
Ya get the ls6 although you will have to figure out what to do about the TB because its smaller on the ls6 but the ls6 manifold consistantly shows gains in power over the ls2.
Old Nov 6, 2010 | 02:23 PM
JustAnotherLS2's Avatar
The LS6 has cathedral style intake ports. The LS3 will not fit because the LS3 intakes have rectangle style intake ports.
Cathedral
LS1/2/6
Rectangle
LS3/7/??9??
LS4, I would imagine it would have the rectangle style intake ports but I'm not sure.
Old Nov 6, 2010 | 02:25 PM
If you can find an L76 intake, that will fit as well.
Old Nov 7, 2010 | 07:47 AM
redbird555's Avatar
L76 intake has the rectangle port heads so it wont work the ls4 intake is a cathedral port also but still inferior to the ls6 which is the best STOCK gm cathedral port intake..
Old Nov 7, 2010 | 10:07 AM
Sorry, guess I misread the OP. I thought you were looking for a rec. port intake.
Old Dec 28, 2010 | 07:56 PM
SoCal_63 SS's Avatar
Nice looking ride! How did the TBSS install go? I am in the process of doing the same... TBSS LS2 into a '63 Nova. I will eventually go with L92 heads, FAST intake, etc... but will probably run the stock TBSS setup for now. Any tips or tricks? Did you run the stock Cam, Headers, intake, etc? What kind of HP/TQ did you get to with your setup?
Any good info would be much appreciated!!!
I would like to at least upgrade the cam and intake, but every time I start thinking about it I end up down the path of having to replace the pulley system, etc, etc, etc... which I don't want to get into until the car is back on the road after a full tear down.
Old Jan 12, 2011 | 01:47 PM
jegten's Avatar
i have a ported ls6 intake with a 92mm snout for sale if anyone is interested.
Old Jan 13, 2011 | 12:03 PM
67RSCamaroVette's Avatar
There is a guy that ports LS2 intakes for about the price of a LS6, and it will outflow the LS6. He removes ribs/casting inside the manifold, and cleans up the runners.
Old Jan 19, 2011 | 08:09 AM
Bludog's Avatar
PM Sent
Old Jan 19, 2011 | 01:06 PM
Honestly looking back at the project I would have just bought a LY6 truck motor instead of the TBSS engine. By the time you spend the money to get into a TBSS LS2 then convert it to a car motor you could have a modded LY6 with the good heads already and LS3 intakes are dime a dozen on ebay. LS2 intakes are made from some form of plastic gold I think. Its only 90 lbs difference going to the iron block but they are around 2k as opposed to 4 or 5 k to buy. Plus they are only 9.4 to 1 as opposed to 10.9 to 1 comp so you can add boost right out of the box. I do not have any power numbers yet due to living in the ice age right now so I have not even pulled it out of the garage. Here are some pics of my engine.
Attached Thumbnails LS6 intake VS LS3-engine2.jpg   LS6 intake VS LS3-engine-3.jpg
Old Jan 23, 2011 | 12:04 PM
Dub Silverado's Avatar
Without digging to much into this or hijacking this thread im also putting a TBSS motor in a classic car and need to switch to a car intake. My question is which one do I need, LS2 or LS3? I am not changing heads just need to swap intakes.
Also which throttle body will I be able to use?
Old Jan 23, 2011 | 12:10 PM
Bumpers's Avatar
You will need a cathedral ls2/ls6 style intake
Old Jan 23, 2011 | 12:12 PM
TransWS6Am's Avatar
not to be rude, but if you read this thread you would have your answer.
Old Jan 23, 2011 | 12:25 PM
I have read the thread as well as about 20 others and they are all conflicting and confusing. There are people talking about ls3 intakes which flow better but from best i can tell you would need to change heads for these to work. I am just looking for a bottom line answer to my question which what im understand is that with a TBSS motor with stock heads I will need an ls2 intake manifold, injectors and rails.
My only last question is what throttle bodies can I use.
Old Jan 23, 2011 | 12:33 PM
TransWS6Am's Avatar
cable or electronic TB?
Old Jan 23, 2011 | 12:35 PM
Electric. I will be going with a custom aftermarket harness so the plug style is not an issue
Old Jan 23, 2011 | 04:03 PM
Default Intake
I just completed the swap into a 69 chevelle. You will need LS2 intake, F body or corvette accessories if you are changing them, F body or corvette water pump and you can use the truck TB if you want to. I bought a complete intake, rails, injectors, and TB for 400. I believe you can use the truck water pump if you use the truck TB and you can use the truck accessories if you relocate the idler pulley for the PS pump. The stock wiring harness is funky if you use it due to it going over the top of the tall truck intake. I completely reworked mine standalone and tucked it all. Also the EGR is slightly different as you cap the hole in the drivers side valve cover and use the line coming out of the valley cover instead which is plugged from the factory on the trucks. The PCV system is under the valley cover so you dont need a PCV valve either. You use the pipe on the passenger side valve cover for filtered fresh air inlet.
Old Jan 23, 2011 | 04:10 PM
Nice chevelle swap. I've got an ls2 in my 70 chevelle with a magna charger. This tbss motor I'm going to be using is going to get an aftermarket serpentine kit so im not worried about the accessories.
I just found the tall edelbrock intake manifolds, might look at one of them if there is hood clearance in my caddy project.
