car missing/stumbling above 6,500 rpms...
Car seems to run strong up to 6,500 rpms. Then, there is a noticeable miss above that.
One of the plug wires seemed a little loose, so I ordered new wires. Not sure why it would only miss above 6,500 rpms with that though.
The miss does not show up on the logs. But again, it is very noticeable at the track.
I have morel limited travel lifters and T & D adjustable rockers. Rocker preload set to specs given by T & D.
Top 3 suspects right now -
1 - Losing spark. Ordered new wires. The current wires are sloppy.
2 - Fuel. Need to check injuector duty cycle, fuel pressure.
3 - Valve float.
Will be too cool if simply changing the plug wires fixes it. But my record would indicate it won't be that easy!
Won't be able to try the stock rockers, they won't work with the limited travel morels. Already tried that before spending the money on the T & D's.
Ok - went did a couple of pulls to check fuel. Didn't lose fuel pressure, held in the mid 50's.
I did notice though that the wideband shows it getting very rich when it starts missing. It drops from 12.8 down to 10.8 - 11.2 range.
