LS2-LS3 compression ratio
Old Nov 10, 2010 | 07:27 AM
Mike Cordero's Avatar
Default LS2-LS3 compression ratio
How differs the compresion ratio in a LS2 with 243 heads from a LS3 with 821 heads? What about using a LS2 with LS3 (821) heads? Do this last combination with probably less compression is better than the others factory ones?
Old Nov 12, 2010 | 05:27 AM
Still wondering??
Old Nov 12, 2010 | 03:21 PM
Jontall's Avatar
https://ls1tech.com/forums/ls1-domes.../t-200043.html
Old Nov 12, 2010 | 03:46 PM
Pony Exp.305's Avatar
Nice information and easy to find...
Old Nov 20, 2010 | 08:57 PM
redsap05's Avatar
The ls2 stock with 243 heads is 10:9:1. The ls3 with stock 821 heads is 10:7:1. A ls2 with ls3 heads will drop down to 10:4:1 due to the 70cc chambers in the ls3 heads. If you mill them you can retain stock ls2 compression but it will kill you ptv clearance.
