Ls3 carb setup, wiring harness and sensor questions!!
a) Can I use a stock wiring harness for a sbc in my camaro instead of using an ls style wiring harness?
b) Do I need to have a computer to run this setup?
C) Can I mate this motor to my 4 speed super t10 tranny?
D) Do I need to hook up the sensors?
Sorry if the answers to these questions are obvious, or if someone has asked before but I can't seem to find where it would be. Any advice or comments would be greatly appreciated!!
B. No
C. Yes
D. Yes and no. The cam and crank sensor will have to be connected if you use the MSD timing box, but not if you put in a distributor.
B. No
C. Yes
Thanks for the info! This cleared a lot of stuff up. So I can run either a distributor or msd ignition box, but which do you think is better/would you prefer?
