FAST 102 hitting Oil Sending switch
Old Nov 20, 2010 | 06:37 AM
davidws6's Avatar
Default FAST 102 hitting Oil Sending switch
Upon pulling off the FAST 102 for a stage 2 intake port on the LS7 heads, the Oil press sending unit was cracked and with a slight push, it broke off.
While re installing the FAST, I noticed that the back intake was hitting the Pressure switch.
I used a file and filed off about 1/8 of in inch on the boss just to the right of the 2nd bolt that holds the top half on.
I called FAST ( Comp ) and dude on the tech line said he'd never heard of it?
I'm using a LS2 block and a LS2 /LS6 valley cover.
Anyone else seen this ? I'm pretty sure the first switch was the original one. I grabbed a new one from SDPC and it looked the same.
I installed the FAST while the engine was in the car so really could not see if it hit or not.
Old Nov 20, 2010 | 01:40 PM
jay_lt4's Avatar
yes,, my fast 102 also hit my oil pressure sender,, i had to re-tighten the sender to turn the connector just a bit to get the intake to fit,, but it is still sitting right against the connector
Old Nov 21, 2010 | 09:52 AM
Jimbo1367's Avatar
Originally Posted by davidws6
Upon pulling off the FAST 102 for a stage 2 intake port on the LS7 heads, ........
.......I'm using a LS2 block .
I assume you had the block sleeved for a 4.125 bore or so?
Old Nov 21, 2010 | 10:00 AM
MrElectric03's Avatar
Thats strange, I wonder if you can use the corvette style pressure sender, its quite a bit shorter.
Old Nov 21, 2010 | 06:15 PM
davidws6's Avatar
Default Bore size
4.185 Darton Dry Sleeves, n no problems with them. Thx to Steve @ R E D !
Corvette sender ? Dunno. I filed the FAST there where it hit and it hit no more. Can't see it now as it's in the car and running. No leaks so that's a good sign !
Old Nov 22, 2010 | 06:11 AM
1lejohn's Avatar
There is no such thing as a bolt on part in the car game. Good info thanks . If it states that the part simply bolts then look out.
