Accel Pedal: Camaro LS3 VS G8
What is the probability that a 2010 Camaro SS LS3 Accelerator Pedal P/N 92199239 will work with a 2009 Pontiac G8 ECM programming? The G8's Accel Pedal P/N is 92213647. Physically they mount the same.
Both the Camaro LS3 and G8 LS3 engines use the same ETC P/N 12605109.
Anybody know if the Camaro pedal will work with G8 programming on a 2009 E38 ECM?
* I have to add the the connectors are in fact different between the 2 pedals, but the circuit number callouts, number of wires, and functional description are the same.
Thanks.
Joe
Thanks.
Joe
Last edited by tijoe; 12-14-2010 at 01:54 PM. Reason: Add comment about connectors
