Heads
Old Dec 19, 2010 | 11:01 PM
05gtoman's Avatar
Default Heads
Searched and searched and can't make a decision on heads for my gto build. Have the fast 102 intake/ NW tb with 4" CAI (not installed yet) kooks headers, magna catback, 3:91's, 6sp with pedders suspension. Was looking at AFR line but dont know what size to get? Have been told 205 to 245 or just port my stock 243's. Any help appreciated. Looking for 450+ rwhp. Also will be getting a medium sized cam to flow with it all! Thxs
Old Dec 19, 2010 | 11:52 PM
hitmanws6's Avatar
My advice to you is to talk to Tony Mamo at AFR and have him guide you on your Heads/cam
Old Dec 20, 2010 | 12:29 AM
05gtoman's Avatar
I did talk with him and he suggested the 215's, which I was already looking at. Some suggest porting the 243's. Just want a head to flow good with the 102 intake and midgrade cam of sumsort to make me some good power. Looking at 450+ rwhp on my LS2.
Old Dec 26, 2010 | 09:04 PM
Mez's Avatar
Mez
Too many choices. Ported 243 heads will get you 450 rwhp although the AFR 215 will probably too. AFR 215 or ported 243 heads from a reputable show with a mild cam is probably the right choice. The AFR 225, 235, 245 are for bigger displacement.
The GTOs are heavy, so you want to keep as much torque and civil idle as you can. With the 6.0 LS2, look at ported 243 heads, 220/228 duration with lift ~ .600" with a 114 to 116 duration. Or call Comp Cams or AFR for their advice.
Old Dec 28, 2010 | 01:38 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
You might take a look at the PRC 215 aftermarket casting heads. Those heads with a torquer v.3 and the supporting modifications you have should be able to meet that goal. The aftermarket casting would allow you to mill the heads and get some extra compression in the motor. I think in order to hit that kind of number with a midranged sized cam having ample compression would be important.
Old Dec 28, 2010 | 04:23 PM
Shawn @ VA Speed's Avatar
the TFS 225's work really good on the 6.0 gto's. We've made 520rwhp with them on a stock bottom end.
Old Jan 5, 2011 | 09:15 PM
05gtoman's Avatar
Thx for the help guys. So let me see here:
AFR 215
TFS 225
PRC 215
PI LXR 215 TO 245
P/P MY 243's
wow, decisons, decisons! Which 1 of these 5 heads will flow great with my 102 setup?? Can't flip a coin on this one. Guess go with the gut. Money no object here.
Old Jan 5, 2011 | 09:43 PM
litle88's Avatar
TFS!!!
and you won't regret it!
Or..........
Go Ls3 baby!
Sell the FAST and just get an Ls3 intake with injectors for 300.00 and Ls3 heads from LPE FOR 1699.00 just saying though. My .02
Old Jan 15, 2011 | 03:34 PM
mikey1107's Avatar
I personally like the PRC'S but if money's no object look at these.
Mast Motorsports
Old Jan 18, 2011 | 07:18 AM
munciegoat's Avatar
Sorry for the hijack but could you pm me the spec's on that build, looking to do some thing similar.
Thanks
Old Jan 20, 2011 | 03:59 AM
05gtoman's Avatar
Great but what size cam, intake, tb, you using??
Old Jan 20, 2011 | 07:06 AM
HPfreak820's Avatar
Subscribing...
Old Jan 20, 2011 | 10:59 AM
litle88's Avatar
Vindicator cam and a FAST 102 is what I'd go with! On my old short block Ls1 I made 457 on a little VRX5 and as cast 220 TFS heads thru an M6 on a Mustang Dyno. You'll love it.
