help scoggin dickey(or anyone else who might know)
Old Jan 10, 2011 | 03:15 PM
RNation0001's Avatar
Default help scoggin dickey(or anyone else who might know)
im building a iron block ls1 from a 08 block so i used a front cover that had the cam sensor in it. well i ordered what i thought was a ls2 sensor for the front cover and it wont fit? anyone know what i do need?
heres what the cover looks like
and heres the sensor in the cover it doesnt even make it in to the oring and the holes dont align
Old Jan 10, 2011 | 03:27 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That looks like it may be a front cover from a FWD application.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 10, 2011 | 03:30 PM
oh lord. so what do i need to do to get it to work?
Old Jan 10, 2011 | 03:38 PM
I do not know of a way to make the cam sensor work in that position without running the FWD vehicle's PCM.
__________________
Old Jan 10, 2011 | 03:40 PM
so theres no way of just using that sensor with the fbody computer? i did get the right timing chain set for the ls1
Old Jan 10, 2011 | 03:44 PM
The issue is PCM is expecting the raised spot(s) to send their signal via the hall effect sensor in a certain window of time in the crank cycle. It knows if it's 180º out and adjust accordingly for the firing order and knows which cycle it's in, but that's not 180º off
Maybe someone else will have an idea, but I've never seen any way to make it work before without swapping the PCM or cover.
__________________
Old Jan 10, 2011 | 03:45 PM
***** batman
Old Jan 10, 2011 | 03:48 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Yup, that's the wrong front cover and it looks like the correct LS2 sensor. I would recommend getting a standard front cover.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 10, 2011 | 03:50 PM
how hard is it to change back out once its sitting in the car. i have the balancer pulley on but the bolt isnt tight yet? any tips on changing it out?
Old Jan 10, 2011 | 04:25 PM
It's as easy as pulling the balancer and swapping covers, nothing to it
__________________
Old Jan 10, 2011 | 07:30 PM
well whats the easiest way to get the balancer back on i cant put a 2x4 in there and hit it with a hammer till i can get the bolt in like i did before lol
Old Jan 11, 2011 | 08:13 AM
Coban's Avatar
https://ls1tech.com/forums/tools-fab...tool-pics.html
Old Jan 15, 2011 | 12:15 PM
LS1MCSS's Avatar
Use the correct tool to install the balancer. Don't beat that thing with a hammer and board.
Old Jan 15, 2011 | 04:35 PM
well when i click on that link it says i dont have permission or somethin. i gotta find something quick so i can get it back on,
Old Jan 15, 2011 | 08:39 PM
S10xGN's Avatar
Originally Posted by RNation0001
well when i click on that link it says i dont have permission or somethin...
Same here...
